DataMiner Object Model: Slow to delete module
Solved1.66K views5th July 2023DOM
Jason Pitteman [SLC] [DevOps Member]556 23rd May 2023 1 Comment
We are trying to delete a complete DOM module with 4540 instances as you can see on the screenshot below:
This process has been running for over an hour but only 110 instances have been deleted.
What could be the reason for this slowness?
Thanks in advance.
Jason Pitteman [SLC] [DevOps Member] commented 24th May 2023
The process is still running and it has deleted 2950 instances in 24 hours so far.
Peter Vanpoucke [SLC] [DevOps Advocate]1.24K Posted 24th May 2023 1 Comment
Hi Jason
It seems that the search engine is quit slow currently. Could you open a ticket so we can further investigate what’s causing that?
Hi Peter,
Thanks for your support.
I’ve opened a ticket for this.
Kind regards,
