Dataminer monitor system
Solved1.50K views30th September 2024
Christopher ESTOCADO22 23rd June 2024 2 Comments
if I want to reset the system without error the input program. it's possible?
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 30th September 2024
Marieke Goethals [SLC] [DevOps Catalyst] commented 27th August 2024
I see that this question has been inactive for some time. Do you still need help with this? If yes, could you answer the questions Ben asked below? Or if not, could you select the answer (using the ✓ icon) to indicate that no further reaction is needed?
Marieke Goethals [SLC] [DevOps Catalyst] commented 30th September 2024
As this question has now been inactive for a long time, I will close it. If you still want more information about this, could you post a new question?
Ben Vandenberghe [SLC] [DevOps Advocate]9.76K Posted 23rd June 2024 0 Comments
Hi Christopher - can you please further elaborate a bit on what it is that you are looking for?  You want to reset the system you mention, but do you mean just reboot or factory reset and clean the system?  And what exactly do you mean by "without error the input program"?
Can you please clarify a bit?  That way we can provide you with the exact information that you are looking for.
