Dataminer is taking longer than 30 minutes to start
Solved2.47K views3rd November 2022
Syed Taj uddin [DevOps Member]403 31st October 2022 2 Comments
Hi, we are using dataminer version 9.5.0.0-8480-CU16, when i restart dataminer it is taking longer time to get start. I am also facing the issue that when i activate the elements it give an errors "failed to start elements" please find the attached screenshot.
Srikanth Mandava [SLC] [DevOps Advocate] Posted new comment 3rd November 2022
Syed Taj uddin [DevOps Member] commented 31st October 2022
Adding more info:
I tried restart dataminer and windows server but no luck its giving an error “No connection with cassandra database at localhost”
Srikanth Mandava [SLC] [DevOps Advocate] commented 3rd November 2022
Syed
I notice that you are still using DataMiner 9.5 version. Do you know that this version is now out of support from Skyline?
Please see https://community.dataminer.services/dataminer-supported-versions-lifecycle/ for details.
Thanks.
Gellynck Jens [SLC]2.72K Posted 31st October 2022 2 Comments
The error alarms indicate the Cassandra database is down, which will indeed increase the startup time. Here you can find a flowchart to troubleshoot Cassandra database issues.
Syed Taj uddin [DevOps Member] Edited comment 31st October 2022
Thank you Jens for your recommendation, the issue was related to Cassandra connectivity. I have changed the parameters in the .yaml file as below and the issue was resolved immediately.
For a single DMA setup:
listen_address: 127.0.0.1
seeds: 127.0.0.1
rpc_address: 0.0.0.0
broadcast_rpc_address: 127.0.0.1
Hi Jens
Can you help me with the root cause of it, why .YAML file got changed, can you confirm if the above rectification is enough and if there will be no impact in future?
