DataMiner does not seem to follow shape ordering in Visio
Solved733 views18th May 2026
Oscar Eves [DevOps Advocate]410 17th May 2026 2 Comments
I have some shapes in Visio that have been order like this, with the yellow box at the back
When I load this in DataMiner the yeloow box is not at the back anymore
Does DataMiner not preseve the shape ordering or does the Show shape data override this?
If so, how shuold something like this be implemented?
Oscar Eves [DevOps Advocate] Selected answer as best 18th May 2026
Miguel Obregon [SLC] [DevOps Catalyst] commented 17th May 2026
Hi Oscar,
Are you linking the shape to a component (element, view, service)?
If this is the case, can you add the following shape data:
– Enabled: False
– Options: NoAlarmColorFill
Oscar Eves [DevOps Advocate] commented 18th May 2026
Yes the shape is linked to a parameter in an element. However, adding those options does not change the behaviour of the yellow box
Miguel Obregon [SLC] [DevOps Catalyst]23.97K Posted 18th May 2026 1 Comment
Hi Oscar,
Can you add the shape data Enabled: False to the circular shapes as well? I made a small test and it seems to work:
Hope it helps.
Thanks Miguel, this works
