DataMiner Dashboard to illustrate my DMS element capacity per DMA
Solved2.90K views25th January 2023dashboards app
Ian Harvey [SLC] [DevOps Member]844 25th January 2023 2 Comments
I am looking to build a dashboard using the Generic Query Interface (GQI) which shows a clear status of element capacity across my DMS.
The idea being I can forecast growth and utilisation.
Ian Harvey [SLC] [DevOps Member] Selected answer as best 25th January 2023
Miguel Obregon [SLC] [DevOps Catalyst] commented 25th January 2023
Hi Ian,
With capacity are you referring to how many elements I can run in a DMA based on the license? Or based on the load (CPU, memory) in a DMA?
Ian Harvey [SLC] [DevOps Member] commented 25th January 2023
The question was not very well phrased. It should read, show the element capacity per DMA within a DMS 🙂 Taking into account active / disabled elements as a filter.
Jens Vandewalle [SLC] [DevOps Advocate]10.01K Posted 25th January 2023 0 Comments
Hi Ian,
If you need something today you might want to build a connector to get this data. This connector can retrieve the number of elements each hour and compare it with the max number of allowed elements on each Agent. If you enable trending on those parameters, you can see how the capacity usage evolves overtime.
Jens Vandewalle [SLC] [DevOps Advocate] Answered question 25th January 2023
