DataMiner Dashboard to illustrate my DMS element capacity per DMA
Solved2.34K views25th January 2023dashboards app
Ian Harvey [SLC] [DevOps Member]844 25th January 2023 2 Comments
I am looking to build a dashboard using the Generic Query Interface (GQI) which shows a clear status of element capacity across my DMS.
The idea being I can forecast growth and utilisation.
Ian Harvey [SLC] [DevOps Member] Selected answer as best 25th January 2023
Miguel Obregon [SLC] [DevOps Catalyst] commented 25th January 2023
Hi Ian,
With capacity are you referring to how many elements I can run in a DMA based on the license? Or based on the load (CPU, memory) in a DMA?
Ian Harvey [SLC] [DevOps Member] commented 25th January 2023
The question was not very well phrased. It should read, show the element capacity per DMA within a DMS 🙂 Taking into account active / disabled elements as a filter.
Wim Bruynooghe [SLC] [DevOps Advocate]6.77K Posted 25th January 2023 1 Comment
If with element capacity you mean the amount of elements then it’s possible with GQI to create a query that counts the amount elements in the DMS, optionally grouped per DMA. But this returns only the current values.
With our upcoming DataAggregator extension module, you could schedule this query to run at a configured interval. These results could be ingested back into DataMiner (or using a custom data source in GQI), allowing to create a dashboard that shows the amount of elements over time.
Ian Harvey [SLC] [DevOps Member] Posted new comment 25th January 2023
Thank you Wim.
Firstly you deciphered the question, which was poorly written 🙂
More importantly, a great route forward. Will try out a dashboard and look to share to others via Dataminer. Services.
Looking forward to the DataAggregator extension module
Jens Vandewalle [SLC] [DevOps Advocate]9.85K Posted 25th January 2023 0 Comments
Hi Ian,
If you need something today you might want to build a connector to get this data. This connector can retrieve the number of elements each hour and compare it with the max number of allowed elements on each Agent. If you enable trending on those parameters, you can see how the capacity usage evolves overtime.
Jens Vandewalle [SLC] [DevOps Advocate] Answered question 25th January 2023
