Dataminer Cube and HTTPS communications
Solved3.01K views12th February 2024Cube HTTPS
Phillip Choi56 2nd January 2024 0 Comments
How can you confirm if the cube communicates to the Dataminer using HTTPS other than a Wireshark capture? Are there any indicators within the cube application to show this? Is it normal for me to see POSTS in HTTP?
POST /SLNetService HTTP/1.1
User-Agent: Mozilla/4.0+(compatible; MSIE 6.0; Windows 10.0.19045.0; MS .NET Remoting; MS .NET CLR 4.0.30319.42000 )
Content-Type: application/octet-stream
Host: x.x.x.x:8004
Content-Length: 1042
........................HandleMessages.kSkyline.DataMiner.Net.ISLNet, SLNetTypes, Version=1.0.0.0, Culture=neutral, PublicKeyToken=9789b1eac4cb1b12......... .... .........MSLNetTypes, Version=1.0.0.0, Culture=neutral, PublicKeyToken=9789b1eac4cb1b12......Skyline.DataMiner.Net.Security.ConnectionToken....
_connectionID._token._seqID....System.Guid............System.Guid....._a._b._c._d._e._f._g._h._i._j._k.......................f..P9.@.Z}$.<.. .......................)Skyline.DataMiner.Net.Messages.DMSMessage.... ...............M.......5Skyline.DataMiner.Net.Messages.Advanced.ZippedMessage....
ZippedData...... ..............PK........
V"X._.-1...........data.RMK.@.M....M<.!7)...A
$.4.ES..^D.&.JH.-......;m...........[f.UQ./i....d.....I...7_......9..7..\....JQ..o..(O...&...k......_...Y...[.]..Y....G.... ....s:.N<?..(...A.0...y.P.O...C.3^gtY{......,.oi..lz.B..:.n....D....<v.)c.,{.Nj..j.[*G=....u+ i.{.._........G.N.x.y a.......H.mT7i.;.......5.`...4.dC~d...@...PK..3.......
V"X._.-1.........................dataPK..........2...S.....
Nils Hoven [DevOps Advocate] Answered question 12th February 2024
Alberto De Luca [DevOps Enabler]5.75K Posted 2nd January 2024 1 Comment
Hi Philip,
how do you connect CUBE?
By using a host name or by specifying the IP address?
If you can't use the BPA, perhaps you can check via CUBE when adding the DMA agent - I cannot remember if this is valid in 10.1, however this might be reflected also in the version you are using:
Even if the server is capable of providing HTTPS, the connection needs to be established by using something like MyDMAname.onMyNetwork.MyDomain in order to trigger https - when connecting CUBE via the IP address, you'd be normally in the case shown on the left - is this of help?
Phillip Choi Posted new comment 2nd January 2024
Phillip Choi commented 2nd January 2024
Hi Alberto,
It does reflect your screenshots, but when parsing the actual Wireshark I’m only seeing HTTP from the server. Client to server it’s tcp binary which I would expect is normal, but I’m seeing this regardless if I have the bindings setup.
