DataMiner as a relay point of Active Alarms towards other systems
Solved1.62K views22nd June 2024adl2099 alarms forwarding Visible alarms
Alberto De Luca [DevOps Enabler]5.75K 16th April 2024 0 Comments
Posting here to attempt to retrieve a comprehensive list of all the possible configurations that can be deployed to relay live alarm information from a DataMiner cluster towards other systems:
– SNMP forwarding (via System Center);
– DataMiner API (GetAlarms?);
– User Defined API (?)
– Kafka integration (using the DMS as a Kafka producer?)
– Correlation>RunScript (?)
– Custom/Bespoke connector
I know that within a general use case the possibilities are virtually limitless, however at this stage I might just want to filter selected alarms from the Active alarms list in console and send them to other collection points (either for real-time parsing or just data collection): any steer on how to do that without necessarily writing a bespoke driver would be extremely helpful.
Thanks
Alberto De Luca [DevOps Enabler] Selected answer as best 22nd June 2024
Miguel Obregon [SLC] [DevOps Catalyst]23.71K Posted 17th April 2024 2 Comments
Hi Alberto,
Another option is to use the DataAggregator DxM.
You could create GQI queries that will be executed remotely from a DMA. This DMA could be located in the same cluster where you would like to get the active alarms or could be from a different cluster.
The execution is defined based on these settings: Cron-trigger
The output of these queries could be:
  • A CSV file stored in the DMA where the DataAggregator is running
  • Through a web socket connection
In GQI there is already a data source that allows you to get the active alarms. Although GQI does not allow you to use saved filters (as far as I remember), you could use the filter operators to get the same result.
Hope it helps.
Alberto De Luca [DevOps Enabler] commented 17th April 2024
Thanks Miguel, surely something to keep on the radar of possibilities.
Will update the list with this suggestion: leaving the thread open for some more time to see if there’s other options too
Alberto De Luca [DevOps Enabler] commented 22nd June 2024
Marking this as solved – thanks
