dataminer agent was not running
Solved1.23K views4th July 2023
praveen sajja [DevOps Member]86 31st May 2023 0 Comments
hi team
we have installed dataminer agent, at login page when we tried to login it was giving error dataminer agent was not running, uploaded screenshot
thanks
s.j.v.praveen
Michiel Saelen [SLC] [DevOps Advocate]6.55K Posted 31st May 2023 2 Comments
Would suggest having a look into the log folder (C:\Skyline DataMiner\Logging) of DM to see what is going on. SLErrors should give you an immediate overview of all errors in all log files. I would suspect it is most likely a licensing issue as you just installed it. This should be visible inside of the SLDataMiner log file.
praveen sajja [DevOps Member] commented 31st May 2023
hi michiel,
in (C:Skyline DataminerLogging) there was not folder in the name SLDataMiner log file.
if it is from licence issue what i have to do?, can i unistall and install again?
thanks
s.j.v.praveen
Michiel Saelen [SLC] [DevOps Advocate] commented 1st June 2023
I assume you used the 10.2 installer from our community platform?
https://community.dataminer.services/dataminer-installer/
I always use the customize button and fill in the details related to the DMA you are installing. That information should be provided with the PO you placed for a DM license. You will need a unique DMA ID from Skyline and in the next steps, the DM software will generate a request file (request.lic) that you need to provide to our licensing team, they will then provide you with a license file that will work for that specific server on which you installed the SW. Did you follow these steps?
For more information best to check our docs:
https://docs.dataminer.services/user-guide/Getting_started/Installing_a_DataMiner_Agent.html
