Dataminer agent is not starting
Solved778 views15th May 2025
Manas CHAKRABORTY [DevOps Member]34 14th May 2025 0 Comments
I am unable to connect the dataminer agent.
Bert Vandenberghe [SLC] [DevOps Enabler] Selected answer as best 15th May 2025
Zain Akhtar [SLC] [DevOps Member]225 Posted 15th May 2025 0 Comments
Update: Tech Support was able to resolve this issue for Manas.
The root cause was that DataMiner had been assigned an incorrect IP address
as the change was not properly done manually. This was purely a configuration issue.
The procedure to update a DataMiner Agent's IP is documented here: Changing the IP of a DMA
