Dataminer agent is not starting
Solved787 views15th May 2025
Manas CHAKRABORTY [DevOps Member]34 14th May 2025 0 Comments
I am unable to connect the dataminer agent.
Bert Vandenberghe [SLC] [DevOps Enabler] Selected answer as best 15th May 2025
Bert Vandenberghe [SLC] [DevOps Enabler]9.75K Posted 15th May 2025 1 Comment
Hi Manas,
It looks like your DataMiner system is probably not correctly started up as it should... It's difficult to troubleshoot this via a Q&A. Therefore, it might be best to contact techsupport@skyline.be or you could also try to start a troubleshooting session yourself with this guidance: Troubleshooting: Where to start? | DataMiner Docs
Bert
Manas CHAKRABORTY [DevOps Member] Posted new comment 16th May 2025
Manas CHAKRABORTY [DevOps Member] commented 16th May 2025
Hello Bert,
Thanks for your concern. I was unaware of the procedure to fix it after changing the IP. It took only 5 minutes to fix it with procedure given by tech support.
Regards,
Manas
