DataAPI element duplication
770 views3rd July 2026DataAPI DataAPI Data Sources
Carl Stanley [DevOps Advocate]271 22nd June 2026 0 Comments
We had an issue recently where an element was created again by DataAPI and I wanted to check a couple of things.
Firstly, is it possible to specify in DataAPI which DMA the elements get created on? Perhaps using appsettings.custom.json?
We had a situation where we have elements hosted on DMA1 that are created by dataAPI, and during a recent upgrade DMA3 came up first while DMA1 was still starting up, DMA3 therefore created the elements on itself as it didn't know they were already on DMA1.
Is there a way to prevent this at all? This doesn't seem like ideal behaviour. As a workaround we will have to be a bit more precise with failovers and reboots, and perhaps stop the DataAPI service on certain DMAs to prevent them creating duplicates. Does this sound feasible?
In an ideal world we would love to be able to specify which DMA should host a DataAPI element, is it possible to raise this a feature request please?
Thanks, Carl
Jan-Klaas Kesteloot [SLC] [DevOps Advocate] Answered question 3rd July 2026
Jan-Klaas Kesteloot [SLC] [DevOps Advocate]1.61K Posted 3rd July 2026 0 Comments
Hi Carl,
Since DataMiner 10.5 CU11, 10.6, and 10.6.2, the Data API creates elements only on the DataMiner Agent where the API is running. In earlier versions, element creation could be distributed across available agents.
I'll reach out directly to discuss your suggestion.
