Dashboards – Trend icon not always visible for element parameters
Solved1.28K views27th January 2025
Jordy Bekaert [SLC] [DevOps Advocate]2.26K 19th September 2024 0 Comments
When working on a Dashboard, the trend icon is visible for one element parameter but not for the other:
Both elements are running the same connector, and are having the same trend and alarm templates assigned. Trending on the parameter is also enabled in Cube.
What could cause this mismatch?
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 27th January 2025
Sebastian Ulloa [SLC] [DevOps Advocate]2.30K Posted 19th September 2024 0 Comments
Hi Jordy,
Is there any chance that the second element got the trend template assigned after the first element? Were you editing the dashboard and then you assigned the trend template to those elements?
I’m wondering if SLHelper hasn’t synced the changes you have done over the elements. If you try restarting the SLHelper process in the task manager, do you get the trend icon updated for the missing element/parameter?
