Dashboards site not working after switch to https with redirect from http to https
Solved2.30K views9th March 2022Dashboards HTTPS
Jeroen Geldhof [SLC] [DevOps Enabler]5.54K 24th February 2022 0 Comments
After changing the configuration according to following and setting up the redirect everything works except the dashboards
https://help.dataminer.services/dataminer/#t=DataMinerUserGuide%2Fpart_3%2FDataminerAgents%2FGeneral_DMA_configuration.htm&rhsyns=%20&rhhlterm=https%20iis
something seems to point to a localhost instead of FQDN
What's the best way to resolve this?
Jeroen Geldhof [SLC] [DevOps Enabler] Selected answer as best 9th March 2022
Gellynck Jens [SLC]2.72K Posted 24th February 2022 5 Comments
Hi Jeroen,
Can you share the configuration of the redirect? Do you still have an HTTP binding in IIS? If so, have you tried using a rewrite instead of redirect?
Felix Wesemeier commented 24th February 2022
Hi Jens,
HTTP Binding still exists.
Did not tried to use rewrite instead of redirect yet.
Redirect configuration below:
Wasn’t able to paste xml here.
Try it without brackets
appcmd
CONFIG CONFIG.SECTION=”system.webServer/rewrite/rules” path=”MACHINE/WEBROO
T/APPHOST/Default Web Site” overrideMode=”Inherit” locked=”false”
system.webServer-rewrite-rules
rule name=”http2https” stopProcessing=”true”
match url=”(.*)” /
conditions
add input=”{HTTPS}” pattern=”off” /
/conditions
serverVariables
/serverVariables
action type=”Redirect” url=”https://{HTTP_HOST}/{R:1}” redirect
Type=”Found” /
/rule
/system.webServer-rewrite-rules
/CONFIG
/appcmd
Gellynck Jens [SLC] commented 7th March 2022
When the dashboards or web API’s are used, they will internally try to connect to its local SLNet using “localhost”. I suspect your redirect rule is causing to redirect http://localhost to https://localhost, which is not a valid subject in your certificate. Would it be possible to try editing your redirect rule to skip the redirect if the hostname is “localhost”? After all, we don’t need to encrypt the traffic on the local server
Felix Wesemeier commented 9th March 2022
Thanks, this solution works.
I added {HTTP_HOST} doesn’t match localhost as a condition to the rule.
Gellynck Jens [SLC] commented 9th March 2022
Happy to help, I will follow up to make sure our documentation is clear on this end
