Dashboards: Errror trapped: InflaterInputStream Position not supported
Solved1.52K views28th August 2024Dashboards
Conan Van Hove [SLC] [DevOps Advocate]899 3rd July 2024 2 Comments
I now get this error when selecting this element (a CISCO Manager).
Strange thing is that this did work before and I could select parameters. But not anymore.
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 28th August 2024
Steve Purcell [SLC] [DevOps Advocate] commented 3rd July 2024
Hi Conan, For comparison, this function is working on Ziine with element SLC-BSW-00-01, Cisco Manager version 5.1.6.5 and Web version 10.4.7(CU0).
Conan Van Hove [SLC] [DevOps Advocate] commented 4th July 2024
And now it also works again for me.
Pieter Van Compernolle [SLC] [DevOps Enabler]4.39K Posted 5th July 2024 1 Comment
Hi Conan,
We have that issue logged in our backlog already (DCP227921). It can occur whenever protocol objects are needed (to for example list their parameters) and the zipped size of the protocol > 1MB.
Please keep us posted on new occurrences.
Conan Van Hove [SLC] [DevOps Advocate] commented 5th July 2024
Hi Pieter,
Thank you for the feedback.
And yes, I found that reference as well and tried to understand its highly technical explanation and how it related to my use case. I just wondered why at one point it works and then later no longer. It must mean that the size of the zipped protocol object somehow sometimes increases above 1 MB, most probably then because of an increased number of table entries somewhere in the element. I will add this example as well to the task. Note that in that case not only the Dashboard editing no longer allows to select parameters and configure components, but also that in existing Dashboards the components already using parameters of these “affected” elements display exactly the same uncomprehensive error (and no longer the expected data, in this case the bitrate of an interface).
