Dashboard – Text input to automation script
Solved939 views23rd January 2025
Stefan Schedletzky [DevOps Advocate]2.48K 20th August 2024 0 Comments
I have a button with an automation script which needs one parameter. This parameter should be filled by my “Text input 2” field. How can I achieve this?
Joachim Ally [SLC] [DevOps Advocate]1.64K Posted 20th August 2024 3 Comments
Hi Stefan,
I assume you mean a Low Code App instead of a Dashboard? Because I do no think you can add a button to a Dashboard.
In case you want this behavior in a Low Code App, you can do this by using the “Feed input”, in the screenshot below I showed an example on where you need to click (6 clicks)  to have the text filled in Text input 2 (in this case “Hello Stefan”) as the input parameter of your script.
Hope this helps you, please let us know if you have more questions.
Kind regards,
Joachim
Wout Mahieu [SLC] [DevOps Catalyst] commented 20th August 2024
FYI: There is a button component available in dashboards (behind softlaunch) that can only launch scripts. This component does not allow linking input parameters to feeds. This is currently only possible in a LCA.
Joachim Ally [SLC] [DevOps Advocate] commented 20th August 2024
Ah nice! Did not know that! Thanks.
Stefan Schedletzky [DevOps Advocate] commented 20th August 2024
It’s almost everytime you want to achieve something, ahh this is not possible
