Dashboard – Read-Write Parameter for every element of a protocol
Solved1.55K views17th July 2023Dashboard
Jan Staelens [SLC] [DevOps Advocate]969 7th December 2021 0 Comments
I was looking into making a quick dashboard to show all the “Relay State” togglebuttons on a single screen to allow me to quickly enable/disable every relay from one screen.
I don’t really want to individually drag and drop the togglebuttons one by one from 50+ elements.
Considering I’ll likely be adding a lot more in the future, I also don’t want to keep having to perform manual maintenance to add them to that dashboard.
I tried queries but those only provide a read-only view from what I could tell.
How can I configure a dashboard component to put all ‘relay state’ read and write  parameters on a single dashboard?
Sebastiaan Dumoulein [SLC] [DevOps Enabler]14.57K Posted 7th December 2021 0 Comments
Hi Jan,
As far as I know this isn’t possible, nor is this something that is on the roadmap. Feel free to create a feature suggestion for this if you think it’s a common user story.
