Dashboard – Node Edge – Panning option
Solved1.98K views8th July 2022Dashboard node-edge
Stacey Van Colen [SLC] [DevOps Member]2.75K 8th July 2022 0 Comments
I have a dashboard which has a node-edge component. It contains a lot of nodes, and many of those nodes are on the same row. We cannot see all the nodes unless we scroll out very far. But we were wondering if, it would be possible to pan around to drag the screen around to get to those nodes left and right of the currently presented nodes?
Kind regards,
Stacey Van Colen [SLC] [DevOps Member] Selected answer as best 8th July 2022
Jeeva Suria Rajah [SLC] [DevOps Enabler]1.87K Posted 8th July 2022 1 Comment
Hi Stacey,
Can you enable the Zooming options in the node edge component as in the picture below?
Stacey Van Colen [SLC] [DevOps Member] Posted new comment 8th July 2022
Stacey Van Colen [SLC] [DevOps Member] commented 8th July 2022
Many thanks for the help Jeeva!
