Dashboard : Get element general properties with GQI
Solved1.95K views23rd December 2021Dashboard Element General property GQI
Wale Oguntoyinbo [SLC] [DevOps Advocate]4.03K 22nd December 2021 0 Comments
I am trying to get a list of elements created on a particular day by using the ‘Created’ date in general properties. Is this possible with GQI ?
Pieter Van Compernolle [SLC] [DevOps Enabler] Answered question 23rd December 2021
Rene De Posada [SLC] [DevOps Advocate]1.93K Posted 22nd December 2021 1 Comment
Wale,
It seems not possible to do this for all elements in the system using GQI. Using the Get Parameter By ID gives you access to the Created Property but only for a single element.
However, you could leverage the pivot table and a parameter feed to achieve what you are looking for.
  1. Create a parameter feed and pass all the elements in your system by dragging the entire element list into the feed
  1. Pass the Property Name and Value parameters from any connector into the parameter feed
  1. Pass the parameters from the feed into the pivot table component and make the necessary selections for “Created”
  1. Export the content from the pivot table into a CSV file and sort by the Created date accordingly
I hope it helps.
Wale Oguntoyinbo [SLC] [DevOps Advocate] Selected answer as best 23rd December 2021
Wale Oguntoyinbo [SLC] [DevOps Advocate] commented 23rd December 2021
Rene, Thanks! for a very detailed answer.
Pieter Van Compernolle [SLC] [DevOps Enabler]3.80K Posted 23rd December 2021 1 Comment
Hi Wale,
I just wanted to add that with we have an internal task on the backlog (id 174186) that will also allow you to use GQI for this use case.
Wale Oguntoyinbo [SLC] [DevOps Advocate] Posted new comment 23rd December 2021
Good to know Pieter. Thanks.
