Dashboard – daily alarm count per element
Solved2.79K views20th March 2024Dashboard
Jeroen Geldhof [SLC] [DevOps Enabler]5.54K 2nd February 2024 0 Comments
Using GQI, is it possible to retrieve a list of the elements with the number of alarms for the last 24 hours in Dashboard?
Also, is it possible to retrieve a list of elements and the percentage they have been in alarm?
Jeroen Geldhof [SLC] [DevOps Enabler] Answered question 20th March 2024
Ward Haeck [SLC] [DevOps Advocate]3.55K Posted 2nd February 2024 0 Comments
Hi Jeroen,
For your first question, you could create a query similar to the following one. In order to get the alarms for the last 24 hours you will need to use a time range component feed.
For the second question I would advise you to use an Ad hoc data source. You can use the GQIDMS object to retrieve data from your DMS. https://docs.dataminer.services/user-guide/Advanced_Modules/Dashboards_and_Low_Code_Apps/GQI/Extensions/API_Reference/GQIDMS.html
You can find some examples on Github:
  • https://github.com/SkylineCommunications/SLC-GQIDS-HighestSeverityAlarmCountPerView
  • https://github.com/SkylineCommunications/SLC-GQIDS-ActiveAlarmsUsingFilter
Hope this helps!
Best regards, Ward
Jeroen Geldhof [SLC] [DevOps Enabler] Selected answer as best 2nd February 2024
Jeroen Geldhof [SLC] [DevOps Enabler]5.54K Posted 20th March 2024 0 Comments
A package has been created and uploaded on the Catalog, which contains a dashboard that gives an overview of the elements and the amount of alarms.
There’s a time range selection as well.
https://catalog.dataminer.services/details/package/5886
