Custom Reports ~ legacy VS new Reporter module
Solved1.67K views6th September 2022adl2099 DMS Reporter Reports and Dashboards
Alberto De Luca [DevOps Enabler]5.36K 6th September 2022 0 Comments
Looking into newer custom reports possibilities - am I correct in assuming that the reporter template API is just for the legacy reporter module?
Thanks
Alberto De Luca [DevOps Enabler] Selected answer as best 6th September 2022
Miguel Obregon [SLC] [DevOps Catalyst]22.20K Posted 6th September 2022 0 Comments
Hi Alberto,
You are correct. This document is related to the legacy reporter module.
