Custom logging levels for processes not listed in Cube logging settings
Solved1.95K views7th March 2023DataMiner Cube logging logs
Alexander Gorbunov [SLC] [DevOps Advocate]1.28K 8th June 2022 0 Comments
Hi Dojo, I’m posting this question to document the answer I got from Laurens Vergote.
It’s possible to configure custom log levels for individual processes in Cube -> System Center -> Logging -> Dataminer. However, some processes are not shown in the list of options, for example SLAlarmForwarding. Is it possible to set custom log levels for such processes?
Robin Devos [SLC] [DevOps Advocate] Selected answer as best 7th March 2023
Alexander Gorbunov [SLC] [DevOps Advocate]1.28K Posted 8th June 2022 0 Comments
Yes, this is possible.
Via SLNetClientTest, using the call UpdateLogFileSettingsMessage:
By editing LogSettings.xml (this requires a DataMiner restart):
When the log level is changed, it is reflected in the respective log file:
