Cube warning – an external application attached to Cube using the microsoft UI Automation Framework
Solved2.19K views28th October 2021Microsoft UI Automation Framework
Jeroen Geldhof [SLC] [DevOps Enabler]5.54K 28th October 2021 0 Comments
What does following message mean, and how can we find out which external application this message is about?
Message : An external application attached to Cube using the Microsoft UI Automation framework. This will have a negative impact on performance and memory usage.
Jeroen Geldhof [SLC] [DevOps Enabler] Selected answer as best 28th October 2021
Lander Vanhaverbeke [SLC] [DevOps Member]1.01K Posted 28th October 2021 0 Comments
It means an external application is attached to Cube, "reading" the UI. When there are a lot of controls visible (for example a big table), this can have an impact on performance.
Cube does not know which application is attached.
If you have a touch screen, it may be TabTip.exe (see if you have running it in the Task Manager). Others tools that do this are Ranorex and screen readers.
If you don't notice the performance impact, there's no need to worry.
