Cube setting – Web browser engine
Solved1.45K views21st April 2023
Arunkrishna Shreeder [SLC] [DevOps Enabler]4.41K 19th April 2023 0 Comments
Hi
Is there a file where the below configuration gets saved ?
It appears when I change this setting, after a day these settings are being overwritten back to the default setting.
Arunkrishna Shreeder [SLC] [DevOps Enabler] Selected answer as best 21st April 2023
Bert Buysschaert [SLC] [DevOps Advocate]5.32K Posted 19th April 2023 1 Comment
Hi Arunkrishna,
This setting (“commonServer.ui.Webbrowser_Engine”) is stored on the DMA in C:\Skyline DataMiner\Users\ClientSettings.json. After saving the setting in Cube, you could have a look at this file on the DMA you are connected to, and on some other DMAs in the cluster, for comparison. There may be an issue with file syncing where the old settings file gets synced from an out-of-sync agent to all other agents during the midnight sync, rolling back your change.
Arunkrishna Shreeder [SLC] [DevOps Enabler] Posted new comment 26th April 2023
Arunkrishna Shreeder [SLC] [DevOps Enabler] commented 26th April 2023
Thanks for the info Bert!
