CUBE> right-click reading >add to dashboard ? (Legacy only?)
Solved1.97K views27th September 2023adl2099 Dashboads dashboards app Service state
Alberto De Luca [DevOps Enabler]5.36K 20th September 2023 0 Comments
When browsing CUBE cards, I can right-click any reading in any element card and select
"Add to dashboards":
in my use-case, I'd need to report into a unified dashboard the "Svc Oper. State" of "MyServiceXYZ"
that should be running across all the DMAs in my DMS - I was thinking to start with an "Add to dashboard" and then create / select a feed to fetch the state across all my DMAs monitored with the Microsoft protocol.
When I right-click & select "Add to dashboards", however,
it seems only a "legacy" dashboard can be created:
Is there a better way to quickly achieve this through the new Dashboards module?
Any config in the DMS so that "Add to Dashboard" links to the newer module?
Thanks
PS: I'm using 10.3.0.0-13184-CU5
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 27th September 2023
Wim Bruynooghe [SLC] [DevOps Advocate]6.77K Posted 22nd September 2023 1 Comment
The "add to dashboard" functionality indeed only works with the legacy Dashboards module.
There's a task (DCP184224) on the backlog to look into this, we could get this working with the new Dashboards app but I think the current idea is to remove this functionality when the legacy Dashboards module is disabled using the "LegacyReportsAndDashboards" soft-launch flag.
Alberto De Luca [DevOps Enabler] Posted new comment 27th September 2023
Alberto De Luca [DevOps Enabler] commented 27th September 2023
Thanks for the insight, Wim – appreciated – would there be any weight if a feature suggestion is logged to keep the functionality?
It used to be a good starting point for a first version of the dashboards in the legacy module.
