Cube Offline Help
Solved1.60K views27th June 2023Cube
Tiago Dias [SLC] [DevOps Member]431 27th June 2023 0 Comments
Currently the default help option on cube, redirects to docs.dataminer.services.
This isn't helpful on systems that don't have direct access to internet. I recall in the past the help option was offline. Is there a way to control this with most recent DMA versions? For instance, via ClientSettings.json?
Ben Vandenberghe [SLC] [DevOps Advocate] Selected answer as best 27th June 2023
Bert Vandenberghe [SLC] [DevOps Enabler]9.75K Posted 27th June 2023 0 Comments
Hi Tiago,
We no longer support offline help. That's a choice we made, and I believe most people will have internet access these days. This way we are able to provide a better and more up to date help online. Advantages outweigh the disadvantages...
Bert
