Cube Launcher Silent installation
Solved2.14K views1st October 2020Cube
6
Michiel Saelen [SLC] [DevOps Advocate]6.55K 1st October 2020 0 Comments
Is there a possibility to install the Cube Launcher through command line with a silent option?
Michiel Saelen [SLC] [DevOps Advocate] Selected answer as best 1st October 2020
Lander Vanhaverbeke [SLC] [DevOps Member]1.01K Posted 1st October 2020 0 Comments
Currently a silent install is not supported. The install procedure is very straightforward though: when you download Cube (from the DataMiner landing page, or from dataminer.services) and execute it for the first time, a window opens with an Install button. Clicking the Install button installs DataMiner Cube with the default options. That’s it.
I understand a silent install could be interesting though. Feel free to create a new feature request and discuss this with your project manager.
Uninstall can be done silently, with the /Uninstall /Silent options (see this resource document).
Lander Vanhaverbeke [SLC] [DevOps Member] Edited answer 1st October 2020
