Cube Landing Page Question using a workspace
Solved1.76K views1st June 2022
Ken O'Connor686 1st June 2022 0 Comments
Hi , I have a Workspace I have saved that just contains a Visio diagram of our World Map view .
I would like ti be able to show this on the initial cube login page when a user logs in. How do I set this up??
Ben Vandenberghe [SLC] [DevOps Advocate] Selected answer as best 1st June 2022
Miguel Obregon [SLC] [DevOps Catalyst]23.71K Posted 1st June 2022 1 Comment
Hi Ken,
You could set a default workspace to a Cube side:
Ken O'Connor [DevOps Member] commented 1st June 2022
Hi Miguel .. yes thanks that is what I have done
Ken O'Connor686 Posted 1st June 2022 0 Comments
Dont worry all.. Ive sorted it.. Just set the default Cube side 1 default workspace to whatever you want in Settings/Cudeb sides..
Ken O'Connor [DevOps Member] Answered question 1st June 2022
