Cube ignore TLS/SSL certificate issue
Solved983 views26th August 2024
Manuel Wals [DevOps Member]252 3rd May 2024 0 Comments
Hi all,
is there an option to ignore TLS/SSL issues when trying to connect with cube via HTTPS?
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 26th August 2024
Bert Buysschaert [SLC] [DevOps Advocate]5.07K Posted 3rd May 2024 0 Comments
Hi Manuel,
At the moment this not possible, unfortunately.
However, this is only during the version checking step of launching Cube. If you have an existing Cube open (for example by connecting to another DMA or cluster), you can logout there, then on the login screen press CTRL-ALT-SHIFT to change the hostname into an editable textbox. Then enter the hostname there. This should allow you to access the DataMiner system until a proper certificate can be configured.
