cube crl freeze BPA reset
Solved908 views3rd June 2026BPA reset
Gerwin van der Kamp [DevOps Advocate]4.09K 3rd June 2026 0 Comments
Is there a way to reset the cube crl freeze BPA to check if there are no new occurences?
Gerwin van der Kamp [DevOps Advocate] Selected answer as best 3rd June 2026
Matthias Declerck [SLC] [DevOps Advocate]3.14K Posted 3rd June 2026 1 Comment
Hi Gerwin,
For the first part of your question (how to reset):
The Cube CRL Freeze BPA checks the number of occurrences based on the SLClient log files on each DataMiner Agent.
If you want to start from a clean slate, there are two options:
  • Restart the DataMiner Agent, which clears the log files on startup
  • Or let new log entries overwrite the old ones over time, which will also remove the previous occurrences from the logs
For the second part (checking for new occurrences):
The BPA details include the timestamp of the most recent occurrence. That makes it easy to see if anything new has happened after the restart.
I’ve added a screenshot from development below. It’s not exactly the same as what you’ll see, but it shows where that timestamp is displayed.
Hope that helps!
Gerwin van der Kamp [DevOps Advocate] Posted new comment 3rd June 2026
Gerwin van der Kamp [DevOps Advocate] commented 3rd June 2026
Indeed, it cleared after an failover/restart 🙂
