Cube color preset for color-blind person
Solved2.80K views10th July 2023Cube
Bernard Pichot [SLC] [DevOps Advocate]1.42K 31st August 2020 0 Comments
Do we have DM/Cube color preset available for color-blind person ?
I found the preset below but don't seems suitable for all color-blind people
<Colors>
<Color type="normal" value="59,120,255"/>
<Color type="warning" value="153,153,204"/>
<Color type="minor" value="97,214,214"/>
<Color type="major" value="245,210,40"/>
<Color type="critical" value="255,127,0"/>
<Color type="notMonitored" value="204,204,204"/>
<Color type="initial" value="242,242,242"/>
<Color type="timeout" value="204,153,0"/>
<Color type="masked" value="136,23,152"/>
</Colors>
Bert Vandenberghe [SLC] [DevOps Enabler]10.11K Posted 31st August 2020 0 Comments
Hi Bernard,
I will probably depend on which type of color blindness we are talking about. In general green, orange and red are the most tricky colors. Here below you can find a color palette optimized for colorblindness and it contains the colors we need, so you can maybe try with some of those colors.
PS: If you figured out better colors which tackle this problem, it would be great if you can post the result here.
