Creating Custom Alarm Property Through Automation
309 views10th March 2026alarms Custom properties
Ana Pinho [SLC] [DevOps Member]1.42K 9th March 2026 0 Comments
Hello Dojo,
Is it possible to create custom properties through automation without having an alarm beforehand?
If so, how can this be done?
Also, is it possible to expose those properties on the Alarm Console through automation?
Thank you!
Thijs Vanovenacker [SLC] [DevOps Advocate] Answered question 10th March 2026
José Silva [SLC] [DevOps Enabler]1.91K Posted 10th March 2026 1 Comment
Hi ana,
Can you try this:
var propertyConfig = new PropertyConfig
Name = property.Name,
Type = "Alarm",
PropertyManager.RegisterPropertyConfig(propertyConfig);
public class PropertyManager
private static ConcurrentDictionary<string, PropertyConfig> registredProperties = new ConcurrentDictionary<string, PropertyConfig>();
/// <summary>
/// Registers a property in DataMiner system.
/// </summary>
/// <param name="property">Property to be registered.</param>
/// <returns>True if the property was registered;otherwise false.</returns>
/// <exception cref="ArgumentNullException">If <paramref name="property"/> is null.</exception>
public static bool RegisterPropertyConfig(PropertyConfig property)
if (property == null)
throw new ArgumentNullException(nameof(property));
if (registredProperties.ContainsKey($"{property.Name}.{property.Type}"))
return true;
var properties = GetRegisteredProperties().ToArray();
if (properties.Any(p => p.Name == property.Name && string.Equals(p.Type, property.Type, StringComparison.InvariantCultureIgnoreCase)))
return true;
var nextId = properties.Select(x => x.ID).Max() + 1;
property.ID = nextId;
try
var response = Engine.SLNet.SendSingleResponseMessage(new AddPropertyConfigMessage(property)) as UpdatePropertyConfigResponse;
return response?.ID == nextId;
catch (Exception)
return false;
/// <summary>
/// Gets an <see cref="IEnumerable{T}"/> of <see cref="PropertyConfig"/> with all registered properties.
/// </summary>
/// <returns>An <see cref="IEnumerable{T}"/> of <see cref="PropertyConfig"/> with all registered properties.</returns>
public static IEnumerable<PropertyConfig> GetRegisteredProperties()
try
var response = Engine.SLNet.SendSingleResponseMessage(new GetInfoMessage(InfoType.PropertyConfiguration)) as GetPropertyConfigurationResponse;
var properties = response?.Properties ?? Enumerable.Empty<PropertyConfig>();
foreach (var prop in properties)
registredProperties.TryAdd($"{prop.Name}.{prop.Type.ToUpperInvariant()}", prop);
return properties;
catch (Exception)
return Enumerable.Empty<PropertyConfig>();
Kind regards,
José Silva [SLC] [DevOps Enabler] Posted new comment 10th March 2026
José Silva [SLC] [DevOps Enabler] commented 10th March 2026
By the way, if the goal is to have the property visible in the Alarm Console, you will need to enable the IsFilterEnabled option when creating it:
Type = "Alarm",
IsFilterEnabled = true
Kind regards,
