Creating Custom Alarm Property Through Automation
315 views10th March 2026alarms Custom properties
Ana Pinho [SLC] [DevOps Member]1.42K 9th March 2026 0 Comments
Hello Dojo,
Is it possible to create custom properties through automation without having an alarm beforehand?
If so, how can this be done?
Also, is it possible to expose those properties on the Alarm Console through automation?
Thank you!
Thijs Vanovenacker [SLC] [DevOps Advocate] Answered question 10th March 2026
Sergio Abreu [SLC] [DevOps Member]196 Posted 10th March 2026 0 Comments
Not sure about the 1st/2nd question.
but for the third question we are using:
hyperlinks.xml or by correlation special paraments Special parameters available in automation scripts | DataMiner Docs
Sergio Abreu [SLC] [DevOps Member] Answered question 10th March 2026
