“Created:/Modified:” info for Services and for Visio files?
Solved3.24K views11th July 2023creation DB queries service general properties visio logs
Alberto De Luca [DevOps Enabler]5.75K 28th January 2022 0 Comments
I'd need to identify which services and Visios have not been updated in the past 9 months - is there any query I can perform to get the created/modified info directly from the DB?
The "Created/Modified" info is something that is available in the general properties but only for elements - any hints?
If this isn't available yet for views and services, I'm happy to raise a feature request.
Ad interim, I was wondering if there is a known event ID that can be searched in the Information Events table, whenever a Visio gets modified or updated, to fetch data & author of the edit.
Thanks,
A.
Pieter Van Compernolle [SLC] [DevOps Enabler]4.39K Posted 28th January 2022 2 Comments
Hi Alberto,
'Created and modified' properties for Services are expected in one of the coming 10.2.x feature releases.
For Visio changes (both assignment and edits) we have information events indeed. In your alarm filter, select 'Information events' and compose a filter based on parameter description by protocol like this:
your result should look like this:
Hope this helps.
Alberto De Luca commented 28th January 2022
Thanks, Pieter – super helpful!
As for the Info events, is there a way to retrieve just the last edit value of a given VDX if the date range is unknown? Also, if I keep only the last year of history in the DMS, does it mean I lose the info about when a Visio was added/edited?
Alberto De Luca commented 8th February 2022
I’m looking forward to tha parts that will be released in the range of 10.2
Logging this for the visio bits, as having the last modification easily accessible can be useful – https://community.dataminer.services/new-feature-suggestions/created-modified-info-for-views-services-and-for-the-uploaded-visio-file-and-visio-preview-when-assigning-existing-visio/
