Create/Next buttons are greyed out during element creation in Properties window.
Solved2.79K views16th June 2023Create Button Create Element Disabled Element Creation element properties
Neetu Pandita [DevOps Member]92 16th June 2023 0 Comments
While creating an element, in the 'properties' tab both Next /Create buttons are greyed out.
There is no property added for the element.
This is causing an issue in creating the element for all the 'Views'.
Neetu Pandita [DevOps Member] Selected answer as best 16th June 2023
Ive Herreman [SLC] [DevOps Enabler]14.55K Posted 16th June 2023 0 Comments
The next button is greyed out because you are already on the last page of the wizard.
The create button is greyed out if you don't have completed all mandatory configurations in the different tabs.
In this case, that means that you have missing configurations on the 'edit' or 'views' pages.
Ive Herreman [SLC] [DevOps Enabler] Answered question 16th June 2023
