create information events (or alarms) from automation script
Solved1.60K views16th September 2022alarm Automation script
Miao Miao398 16th September 2022 0 Comments
Hi
Is there possible to create alarms or information events (which will be shown in Information Events or alarm tab in the CUBE client) from a automation script?
Thanks
Ben Vandenberghe [SLC] [DevOps Advocate] Selected answer as best 16th September 2022
Michiel Saelen [SLC] [DevOps Advocate]6.34K Posted 16th September 2022 0 Comments
Hi Miao,
Hope this helps:
Let us know if you have other questions.
The following course might be of interest:
DataMiner Automation - DataMiner Dojo
