Create element with SmartSerial Connection from script
Solved1.08K views6th July 2023
Julio Riambau [SLC] [DevOps Member]302 21st March 2023 0 Comments
I’m trying to create an element with the protocol CISCO Manager version 5.1.6.19 from an automation script.
it contains an SNMP Connection and an IP Connection to listen for Syslog.
Which would be the recommended method to create such type of elements?
thanks in advance.
Laurens Moutton [SLC] [DevOps Enabler]9.65K Posted 22nd March 2023 0 Comments
At this moment the class library doesn’t support yet creating an element with a (smart)serial connection.
I would suggest to use an “AddElementMessage” SLNet call to create the element from an automation script. If it’s not clear on what fields that should be filled in, follow the DataMiner Cube client with the SLNetClientTestTool while first manually creating a new Cisco Manager element.
Regards,
