Could not attach to SLAutomation Process for managed debugging
Solved779 views3rd July 2023Debug Automation SLAutomation process
Anna Carlsson [DevOps Member]444 3rd July 2023 0 Comments
Hello all!
I'm trying to debug an automation script over a remote DMA server and after follow the instructions at dojo video tutorial I'm receiving an errorn when trying to attach the SLAutomation process.
Msvsmon is up and running and I've configured my DIS to connect to that server/port
When trying to attach I have the following error.
DIS Version: 2.41.1.26
Visual Studio Version: 16.0.32929.386 D16.11
Windows Version: Microsoft Windows NT 10.0.19045.0
.NET Version: 4.0.30319.42000
Connected DataMiner Version: 10.2.0.0
Subscribed to updates: True
Subscribed to insider builds: False
User: Anna Carlsson
Please advice.
Ben Vandenberghe [SLC] [DevOps Advocate] Selected answer as best 3rd July 2023
Anna Carlsson [DevOps Member]444 Posted 3rd July 2023 0 Comments
Hi all,
I found the issue. msvsmon must be started with "Run as Administrator".  This solved the problem. Thanx.
