Could not apply credentials, or the engine ID discovery timed out
Solved1.78K views19th July 2023
Carlos Trejo20 24th February 2021 1 Comment
I am working in a DMS and I am getting this error with a Juniper device, has anyone encountered this error before?
This is what we get back from the Streamviewer:
Thanks in advance,
Carlos
Carlos Trejo commented 25th February 2021
Just added the streamviewer data for extra info.
Wale Oguntoyinbo [SLC] [DevOps Advocate]4.50K Posted 24th February 2021 2 Comments
I encountered a similar error on a DMA running version 9.6.10. The issue is addressed in RN22912  released in 9.6.11. Probably it is the same case here and a DMA upgrade should resolve the issue.
Carlos Trejo commented 24th February 2021
Hi Wale,
Thanks a lot for your response. The interesting thing here is that we have about 6 Juniper elements and only getting that error message for one of them.
Could it be something else?
Thanks!
Wale Oguntoyinbo [SLC] [DevOps Advocate] commented 25th February 2021
Hi Carlos,
Difficult to say what the issue could be . Since you say its peculiar to one Juniper device could you check the device configuration is set to SNMP V3. Other than that I would suggest you contact our support team who can help dig further.
