Correlation Engine Upgrades
Solved1.53K views20th October 2023
ryan yahia900 8th August 2023 1 Comment
I have put the question to tech support but it would be best to add here for greater overview too.
I have checked out the release notes for 10.3.7 and was trying to find updates to the correlation engine, which I think there were some. Is there any release notes surrounding updates to the correlation engine for this particular release or other 10.3.X upgrades.
ryan yahia Selected answer as best 20th October 2023
Marieke Goethals [SLC] [DevOps Catalyst] commented 18th October 2023
I see that this question has been inactive for some time. Was the answer below what you needed? If yes, could you select it with the ✓ icon? If not, could you provide some more information as requested in the answer?
Ive Herreman [SLC] [DevOps Enabler]14.80K Posted 8th August 2023 0 Comments
Hi Ryan,
Looking at the release notes, I could only spot one release note regarding correlation for the 10.3.X Feature release.
1. DMA 10.3.4: RN35583
Can you provide some more details about what information you are looking for?
