Connector “NetInsight Nimbra 4.1.4.1”: Not possible to monitor “Physical Ports”
Solved569 views16th December 2025Alarm Template Table Connector nimbra
Jörg Knesebeck [DevOps Enabler]238 8th December 2025 0 Comments
currently we are trying to monitor the "Physical Ports" of a Nimbra node with DataMiner (10.5.0), without success. The table is available in the related element page, but not in the alarm template (see screenshots below).
Although I checked everything I could in the element, in the alarm template and in the connector xml, I wasn’t able to figure out the problem.
Maybe I’m missing something. Any suggestions? Can anyone help?
Thanks
Jörg
Jörg Knesebeck [DevOps Enabler] Selected answer as best 16th December 2025
Fenta Alemahu [SLC] [DevOps Advocate]1.32K Posted 8th December 2025 2 Comments
Hi Jorg,
Which specific parameters/column parameter do you want to monitor? All the parameters that are shown in the alarm template screenshot you shared are available for monitoring. You need to select the parameter you want and fill in the thresholds.
If you are looking for a parameter that is not listed in the above screenshot, get in touch with your Skyline contact and the necessary changes can be done to the connector to make the parameter available for monitoring.
Fenta Alemahu [SLC] [DevOps Advocate] Posted new comment 8th December 2025
Jörg Knesebeck [DevOps Enabler] commented 8th December 2025
Hi Fenta, thanks a lot for your quick response.
Actually, we are kind of familiar with selecting parameters/columns for monitoring. However, here we have a different issue, I think: The table we would like to monitor is "Physical Ports – *Interfaces*", as indicated in my first screenshot.
In the Alarm Template, from the Physical Ports page, this whole table is not available. Only the table "10G Physical Trunks Ports" is available, but that's not what we need.
Anyway, we learn from your answer that we'll obviously have to contact one of our Skyline contacts in order to get this table monitored, i.e. offered in the alarm template.
Best Regards – Jörg
Fenta Alemahu [SLC] [DevOps Advocate] commented 8th December 2025
Hi Jorg,
Indeed the the column parameters for the Interfaces table are not available for alarming/monitoring. So, as I indicated in the response, reach out to your Skyline contact to check the possibility of monitoring for those parameters.
