[Connection State] parameter (parameter ID 65045) use inside protocol
Solved1.77K views18th June 2021Connection State
Fernando Ejarque [DevOps Member]12 17th June 2021 0 Comments
Hi guys,
I would like to know how can I use the [Connection State] parameter (parameter ID 65045) in the [Connection Info] table on the GENERAL PARAMETERS page of the element inside the protocol to trigger an action when the status is “Disconnected”.
Thanks in advance,
Fernando Ejarque [DevOps Member] Selected answer as best 18th June 2021
Laurens Moutton [SLC] [DevOps Enabler]9.62K Posted 18th June 2021 1 Comment
That is possible by triggering with a QAction on that parameter id with the row true attribute: (tested with DataMiner version 10.1.6.0)
QAction id=”65045″ encoding=”csharp” triggers=”65045″ row=”true”
In that QAction to get the row that triggered it by calling:
string rowKey = protocol.RowKey();
Use that rowKey to know the actual value of the connection state:
string connState = Convert.ToString(protocol.GetParameterIndexByKey(65034, rowKey, 4));
That connState can have the following values:
0 = Responding
1 = Not Responding
2 = Undefined
3 = Connected
4 = Disconnected
Value “4” will probably be the one that you’ll be interested in as that stands for “Disconnected”.
Fernando Ejarque [DevOps Member] Posted new comment 18th June 2021
Fernando Ejarque [DevOps Member] commented 18th June 2021
Thank you so much!!
