Connection of Miranda – HCO-3901
1.16K views27th April 2026HCO iControl miranda Telegram App
Chun Wa Chan [DevOps Member]49 24th April 2026 0 Comments
Are you aware of how to set up Miranda iControl General - HCO-3901 on the densite frame to the DMA without using an appserver?
Chun Wa Chan [DevOps Member] Answered question 27th April 2026
Wale Oguntoyinbo [SLC] [DevOps Advocate]4.50K Posted 25th April 2026 0 Comments
I believe the options provided by Grass Valley(GV) for monitoring and control are via the iControl application server or GV Orbit of which there are these two supporting connectors in the Catalog.
  1. Miranda IControl General
  2. Grass Valley Orbit
Wale Oguntoyinbo [SLC] [DevOps Advocate] Answered question 25th April 2026
Chun Wa Chan [DevOps Member]49 Posted 27th April 2026 2 Comments
| DataMiner System                       |
| (DMA / Servers)                          |
Management VLAN (e.g., 10.10.10.0/24)
|                      v                            |
| DataMiner Agent (DMA)                |
| IP: 10.10.10.100/24                     |
| ports: 5001, 5006, etc.                 |
Control/Orchestration VLAN
|                      v                            |
| GV Orbit / App Server                   |
| IP: 10.20.20.50/24                       |
| (Orbit web service, API)                |
|                      v                           |
| Ethernet (control)                        |
|                       v                         |
| Densité Frame Controller             |
| IP: 10.30.30.10/24                     |
| (in‑frame control bus)                  |
|                      v                           |
| HCO‑3901 Signal Card                 |
| (in Densité slot)                          |
| - no direct IP to DMA                   |
| - controlled via frame/orbit          |
Would DMA circumvent iControl Application Server or Orbit to access HCO-3901 data?
Chun Wa Chan [DevOps Member] Posted new comment 4th May 2026
Wale Oguntoyinbo [SLC] [DevOps Advocate] commented 1st May 2026
As mentioned in my answer, monitoring is designed around iControl and GV Orbit. If you have direct access to the card, the question remains how will you monitor it? Is there an SNMP agent on the card itself or other monitoring protocol? These are questions best posed to the vendor Grass Valley.
Chun Wa Chan [DevOps Member] commented 4th May 2026
Thank you for your thorough and clear answer.
