Connecting to a DaaS system with Client Test tool
Solved1.62K views31st May 2024
Reinout Daels [SLC] [DevOps Member]787 31st May 2024 0 Comments
Is it possible to connect to a DaaS system using the Client Test tool on my pc? I've tried to connect to host 'mysystem-myorg.on.dataminer.services' with my username and password but get the following error:
Reinout Daels [SLC] [DevOps Member] Selected answer as best 31st May 2024
Reinout Daels [SLC] [DevOps Member]787 Posted 31st May 2024 1 Comment
Hi Jordy,
Thanks for your reply! This is what my Client Test tool looks like:
I assume I have an older version of the Client Test tool. Do I need to upgrade my local DataMiner system to get the latest version or is there a quicker way?
Jordy Ampe [SLC] [DevOps Advocate] Posted new comment 31st May 2024
Jordy Ampe [SLC] [DevOps Advocate] commented 31st May 2024
I’m not sure if the client test tool is included in an update of the Skyline Taskbar Utility (and where to find an update for this utility either). Otherwise yes you will have to update your local DM to have a newer version of the client test tool.
