Configuring DIS for a Cloud DMA utilising a SAML connection
Solved2.12K views21st February 2024DataMiner Integration Studio SAML Visual Studio
Garry Metcalfe [DevOps Member]156 1st August 2023 0 Comments
I am using Visual Studio 2022 and I am attempting to configure my DIS extension to connect to an AWS EC2 hosted DMA. The authentication protocol required is SAML. It is however not working correctly.
The SAML connectivity works correctly when used in other applications, and I am wondering if there are any particular configuration steps I need for SAML.
Michiel Oda [SLC] [DevOps Advocate] Answered question 21st February 2024
Tom Waterbley [SLC] [DevOps Enabler]10.01K Posted 2nd August 2023 1 Comment
Hi Garry, SAML authentication is currently not supported by DIS yet, but it is on our roadmap to add it (internal task 184159).
Feel free to still send a feature suggestion to support this here: https://community.dataminer.services/feature-suggestions/.
Marieke Goethals [SLC] [DevOps Catalyst] Selected answer as best 7th August 2023
Garry Metcalfe [DevOps Member] commented 7th August 2023
Hi Tom, thank you very much for the update, I will put the suggestion in as you mention
