Conditional alarm exclude on Not Initialized
Solved689 views16th July 2026alarming conditional alarm filter
Mieke Dryepondt [SLC] [DevOps Advocate]4.29K 16th July 2026 0 Comments
How to configure a Conditional alarm (exclude) when a given param has no value (not initialized)?
Mieke Dryepondt [SLC] [DevOps Advocate] Selected answer as best 16th July 2026
Miguel Obregon [SLC] [DevOps Catalyst]23.97K Posted 16th July 2026 3 Comments
Hi Mieke,
I believe this should be supported. You should be able to find the option 'Not Initialized' when configuring the value for the condition.
Update:
String Parameter:
Hope it helps.
Mieke Dryepondt [SLC] [DevOps Advocate] commented 16th July 2026
I do not have that option.
Is it possible that in your case the connector param has an Exception value Not initialized? Or that Column params behave different from stand-alone. (your screenshot shows "all rows"
In my case I have a stand-alone text param, no default value, no exception value, no discreet, no write param.
The condition box is only providing me a text box without options.
Miguel Obregon [SLC] [DevOps Catalyst] commented 16th July 2026
Hi Mieke,
I updated the answer with a screenshot from a string parameter. Are you able to see the 'Not Initialized' option?
Yes, thank you. I did not think of clicking on "value"
Works perfectly.
