Compression method used for Dashboard URL?
Solved8.87K views19th September 2022Dashboard URL
Gabriel Borges [SLC] [DevOps Advocate]769 19th September 2022 0 Comments
Hello Dojo,
I am trying to create a Dashboard link to preselect some data in a GQI Filter component upon opening and unable to figure out the syntax. I see the URL changing when adding a filter, so trying to reverse engineer the syntax, but unable to figure out what compression method it uses to see the JSON structure. Is there a way to see the uncompressed JSON structure in the URL? Or an entry in the Help with the full structure of the query in the format of a JSON string?
Many thanks in advance.
Gabriel Borges [SLC] [DevOps Advocate] Selected answer as best 19th September 2022
Sebastian Ulloa [SLC] [DevOps Advocate]2.34K Posted 19th September 2022 1 Comment
I think this is what you are looking for: Specifying data input in a dashboard URL | DataMiner Docs
Gabriel Borges [SLC] [DevOps Advocate] Posted new comment 19th September 2022
Gabriel Borges [SLC] [DevOps Advocate] commented 19th September 2022
Thank you Sebastian, I already looked over that and the only example for passing in a GQI Filter is “?queries=[queryAlias]/{“ID”: “Elements”}” and I unfortunately am unable to figure out the syntax for what I need to do with that, which is pass in a filter for a selected table column.
