Compression method used for Dashboard URL?
Solved8.44K views19th September 2022Dashboard URL
Gabriel Borges [SLC] [DevOps Advocate]759 19th September 2022 0 Comments
Hello Dojo,
I am trying to create a Dashboard link to preselect some data in a GQI Filter component upon opening and unable to figure out the syntax. I see the URL changing when adding a filter, so trying to reverse engineer the syntax, but unable to figure out what compression method it uses to see the JSON structure. Is there a way to see the uncompressed JSON structure in the URL? Or an entry in the Help with the full structure of the query in the format of a JSON string?
Many thanks in advance.
Gabriel Borges [SLC] [DevOps Advocate] Selected answer as best 19th September 2022
Gilles Bara [SLC] [DevOps Advocate]7.23K Posted 19th September 2022 1 Comment
Hi
The data used in the url is compressed through LZ compression. The raw data is a json string that uses the format that is described in the DataMiner Docs. There’s a trick to see the uncompressed data: Go to the sharing menu of your dashboard and pick the Url option. There you have a way to toggle compression. Pasting that url in a url decoder will give you the json object of the current state of your dashboard.
The way query filters in particular are serialised is as follows:
v:[version]|[query id]%1e[column ID]%1e[filter type]%1e[filter values]
Where
  • Version is a version number, currently at 1.
  • Query id is the id of the query, can be inspected in the json of the dashboard or network requests (OpenQuerySession).
  • Column ID is the ID of the column, can be inspected through the network requests (GetQueryColumns).
  • Filter type indicates the way the filter is used: supported values are list, range, boolean, number and string.
  • Filter values is the value that belongs to a specific filter type:
    • list: [value 2]%1f[value 2]%1f[…]
    • range: [min: number]%1f[max: number]%1f[include min: boolean]%1f[include max: boolean]
    • boolean, number, string: the actual value
Some examples:
  • v:1|d467f43a-b810-4214-b3f7-22d69b7790a0\u001e1_State\u001elist\u001eHidden\u001fStopped\u001fDeleted
  • v:1|d467f43a-b810-4214-b3f7-22d69b7790a0\u001e3_Aggregation\u001erange\u001e0\u001f100\u001ffalse\u001ftrue
  • v:1|d467f43a-b810-4214-b3f7-22d69b7790a0\u001e1_Is_Active\u001eboolean\u001etrue
We know this isn’t a very user friendly format to contruct manually, but we reached a point where the url needs to be able to do that much that keeping it user friendly would reduce the efficiency/maintainability.
I hope this will help you further.
Gabriel Borges [SLC] [DevOps Advocate] commented 19th September 2022
You are an absolute legend, this is exactly what I was looking for, thank you so much!
Sebastian Ulloa [SLC] [DevOps Advocate]2.30K Posted 19th September 2022 1 Comment
I think this is what you are looking for: Specifying data input in a dashboard URL | DataMiner Docs
Gabriel Borges [SLC] [DevOps Advocate] Posted new comment 19th September 2022
Thank you Sebastian, I already looked over that and the only example for passing in a GQI Filter is “?queries=[queryAlias]/{“ID”: “Elements”}” and I unfortunately am unable to figure out the syntax for what I need to do with that, which is pass in a filter for a selected table column.
