Column order cube
Solved1.63K views23rd October 2023Connector Cube driver
Timothy Van Poucke [SLC] [DevOps Advocate]1.38K 23rd October 2023 0 Comments
Is it possible to change the order of the columns of a table in a connector from cube and save this for everyone? I know we can rearrange the order of the columns and save this by right clicking on the headers and chose "Save Layout" but this is only for the user that did the change as I understand it. Is there a way to do it for all the users in one go? (thought this might be possible with information templates but can't find any doc supporting this theory)
Thanks in advance.
Timothy Van Poucke [SLC] [DevOps Advocate] Selected answer as best 23rd October 2023
Miguel Obregon [SLC] [DevOps Catalyst]22.42K Posted 23rd October 2023 0 Comments
Hi Timothy,
As far as I know this option is not available yet. There is already a feature suggestion about this topic:
Have a 'Save Layout' global option for device details
