Color box based on color code.
Solved1.31K views7th July 2023
8
Samuel Duarte [SLC] [DevOps Advocate]389 22nd February 2023 2 Comments
Is it possible to display a color box based on the color code (example: #df6627)? As an example, something similar to this:
Ive Herreman [SLC] [DevOps Enabler] commented 22nd February 2023
Hi Samuel,
Where would you like to see the color box?
In the low-code apps, visio drawing, other?
Samuel Duarte [SLC] [DevOps Advocate] commented 22nd February 2023
Hi Ive,
I would like to see it as a table column in a protocol.
Karel Lodefier [SLC] [DevOps Member]724 Posted 22nd February 2023 1 Comment
Hi Samuel,
do you prefer any random color, or some fixed/pre-defined ones?
That should be possible using the iconref. A few colors are currently available in a circle format (see below example). Many colors are already available in a rectangle format.
Example:
Hi Karel,
I would prefer any random color if possible, but I will take look on the pre-defined ones.
